Latest post 02-03-2008 11:03 AM by Movie. 7 replies.
Page 1 of 1 (8 items)
  • 02-03-2008 3:11 AM
    • Movie
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 90
    DVD1 Cleaning Lens
    Is it OK to clean lens myself or is it best to let dealer do it - can  anyone recommend  cleaning kit.
    Movie
  • 02-03-2008 4:00 AM In reply to
    Re: DVD1 Cleaning Lens
    I see no reason you cannot do it. I use a cotton bud and some isopropyl alcohol on CD players. You don't need to do it very often!
  • 02-03-2008 4:43 AM In reply to
    Agree with Peter
    Regards Graham
  • 02-03-2008 6:15 AM In reply to
    • Movie
    • Posts 90
    Peter Graham thank you, - Peter how exactly do I go about cleaning the lens,I have never done it before.
    Movie
  • 02-03-2008 7:31 AM In reply to
    Hello,
    You do not have to do it if works fine. But, if your DVD/CD player has a problem, I'm affraid lens has to be changed.
    Basically, if works ok, I mean - no stops or frozen picture, etc, just enjoy,  DO NOT TOUCH !
  • 02-03-2008 8:08 AM In reply to
    • Movie
    • Posts 90
    Hi rotel1111
    I am having some problems at some points while watching dvd it freezes and jumps to next chapter, do you think this means new lens, what is cost of lens replacement.
    Movie
  • 02-03-2008 8:44 AM In reply to
    If your DVD1 has a problem then you can do no more harm by cleaning the lens. Simply remove the top of the case and the lens is obvious.
    Regards Graham
  • 02-03-2008 11:03 AM In reply to
    • Movie
    • Posts 90
    Thanks Graham
