Is it OK to clean lens myself or is it best to let dealer do it - can anyone recommend cleaning kit.
Movie
Regards Graham
Peter Graham thank you, - Peter how exactly do I go about cleaning the lens,I have never done it before.
Hello,
You do not have to do it if works fine. But, if your DVD/CD player has a problem, I'm affraid lens has to be changed.
Basically, if works ok, I mean - no stops or frozen picture, etc, just enjoy, DO NOT TOUCH !
Hi rotel1111
I am having some problems at some points while watching dvd it freezes and jumps to next chapter, do you think this means new lens, what is cost of lens replacement.
