I currently have in a room
BV7-32 & BL7.1
BL6000
BL2
I am trying to remove the speakers off the floor, going to wall hang or table top the TV and BL7. Looking to replace the BL6's. Any suggestions?
I was thinking I would replace BL6's for BL3's and keep the BL2. These would be either wall mounted as fronts, about 4 feet either side of the TV, or table top stands, again about 4 feet from each side of the TV. BL2 would remain on the floor behind the sofa.
I'd rather not have things wall mounted high is corners (rather have a little more flexibility in the future about location) and can't be floor stands as too fragile (little children that have toppled by BL6's many times).
BL5's are not in the equation as I do actually have a budget!!!
I'd appreciate your views. Room is 6m x 9m, wooden floors, high ceiling. Viewing is across the shorter distance (large windows at either end of the long distance).
Hope this is enough info without actually giving you my address and inviting you all around for a demo!
Barny
