Latest post 01-23-2008 4:39 AM by TS4. 7 replies.
Page 1 of 1 (8 items)
  • 01-20-2008 1:42 PM
    • TS4
    • Not Ranked
    • Joined on 12-23-2007
    • Posts 12
    BV7 MkIII and DBox2, AC3 with S/P DIF
    Hello,
    i have a problem to digitally connect my settopbox Dbox2 to the BV7.
    I want to use the digital AC3 sound of the box and therefore i have connected the box via scart (AV1 for the picture) + spdif (for the sound). I had to convert the optical signal of the box to an electric one (cinch) for the BV7. How am i able to tell my BV7 to use the sound of the spdif? In the options menu it is only possible to select spdif when HDMI (A-D) is selected (!).
    Thanks for help
    Regards
    TS
  • 01-21-2008 6:57 AM In reply to
    Re: BV7 MkIII and DBox2, AC3 with S/P DIF
    You don't have to. If there is SPDIF signal detected the Beo 7 switches over to SPDIF. Works just fine
  • 01-22-2008 6:37 AM In reply to
    • TS4
    • Not Ranked
    • Posts 12
    thanks, but it does NOT work in my case ;-(
    any other idea?
    thanks
    ts
  • 01-22-2008 7:40 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    What D-Box software do you use (Neutrino/Enigma)?
    There should be a system setting, audio/sound - use ac3 default output...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-22-2008 8:53 AM In reply to
    In that case you probably don't have a SPdif signal (I presume you connected the right input)
     Check if the box is indeed sendig optical SPdif  (you see a led flashing), if so check if there is an electrical spdif signal (see wikipedia how to do that)
    succes
  • 01-22-2008 2:41 PM In reply to
    • TS4
    • Not Ranked
    • Posts 12
    the box sends an optical signal => i can see thee red light.. When it is true, that the BV7 notices when there is an electical signal the problem has to be with the transformer or the electrical cable. can you give me a link where i can read how to check if there is an/ the right electrical signal? i have searched for it but nothing found...
    thanks a lot
    TS
  • 01-22-2008 3:02 PM In reply to
    • kallasr
    • Posts 1,077
    Just to double check: at the moment you get no sound at all while chosing a tv station that is sending ac3?
    If you still hear sound, it is stereo only and your box is not set to AC3 - see my post above.
    Ralf
  • 01-23-2008 4:39 AM In reply to
    • TS4
    • Not Ranked
    • Posts 12
    Danke für den Tipp Ralf, leider wird bei der Umschaltung an der Box auf AC3 der Ton am TV ausgeschaltet ;-(
    Nur über den Scart-Anschluss wird Ton, dann aber leider nur 2-Kanal, über den BV7 ausgegeben. Über den elektrischen S/P dif-Eingang des BV7 kommt bei Umschaltung der Box auf AC3 - damit optischer Ausgang der Box mit AC3- leider nichts an..
    Gruß
    TS
