1st March February 2012
Latest post 01-23-2008 4:39 AM by TS4. 7 replies.
01-20-2008 1:42 PM
TS4
- Joined on 12-23-2007
- Posts 12
BV7 MkIII and DBox2, AC3 with S/P DIF
Hello, i have a problem to digitally connect my settopbox Dbox2 to the BV7. I want to use the digital AC3 sound of the box and therefore i have connected the box via scart (AV1 for the picture) + spdif (for the sound). I had to convert the optical signal of the box to an electric one (cinch) for the BV7. How am i able to tell my BV7 to use the sound of the spdif? In the options menu it is only possible to select spdif when HDMI (A-D) is selected (!). Thanks for help Regards TS
rvanham
- Joined on 10-25-2007
- Posts 25
Re: BV7 MkIII and DBox2, AC3 with S/P DIF
You don't have to. If there is SPDIF signal detected the Beo 7 switches over to SPDIF. Works just fine
TS4
- Posts 12
thanks, but it does NOT work in my case ;-( any other idea? thanks ts
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
What D-Box software do you use (Neutrino/Enigma)? There should be a system setting, audio/sound - use ac3 default output... Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
rvanham
- Posts 25
In that case you probably don't have a SPdif signal (I presume you connected the right input) Check if the box is indeed sendig optical SPdif (you see a led flashing), if so check if there is an electrical spdif signal (see wikipedia how to do that) succes
TS4
- Posts 12
the box sends an optical signal => i can see thee red light.. When it is true, that the BV7 notices when there is an electical signal the problem has to be with the transformer or the electrical cable. can you give me a link where i can read how to check if there is an/ the right electrical signal? i have searched for it but nothing found... thanks a lot TS
kallasr
- Posts 1,077
Just to double check: at the moment you get no sound at all while chosing a tv station that is sending ac3? If you still hear sound, it is stereo only and your box is not set to AC3 - see my post above. Ralf
TS4
- Posts 12
Danke für den Tipp Ralf, leider wird bei der Umschaltung an der Box auf AC3 der Ton am TV ausgeschaltet ;-( Nur über den Scart-Anschluss wird Ton, dann aber leider nur 2-Kanal, über den BV7 ausgegeben. Über den elektrischen S/P dif-Eingang des BV7 kommt bei Umschaltung der Box auf AC3 - damit optischer Ausgang der Box mit AC3- leider nichts an.. Gruß TS
Page 1 of 1 (8 items)
