Latest post 01-16-2008 3:22 AM by Santiago. 5 replies.
Page 1 of 1 (6 items)
  • 01-15-2008 2:32 AM
    PIP window on screen position
    I'm trying to make 4 macros for 4 commands: the 4 on screen different positions for the little PIP window.
    With Beo4 I must press "P_in_P" followed by a color key... but with beo5 I can't do this Confused
    Help!
    Thanks in advance.
    Santiago
  • 01-15-2008 4:16 AM In reply to
    Re: PIP window on screen position
    Which IR-codes do you use? Details please!
    /Frank
  • 01-15-2008 5:03 AM In reply to
    frankmj:
    /Frank
    Details:
    I'm trying changing PinP window position on the avant32DVD screen with HDR2 attached.
    I've tried those IR codes inside "P in P..." beo5 submenu screen:
    a.- only the 4 simple colours keys:
    "green"="0:000:TV:CNTL_REWIND",
    "yellow"="0:000:TV:CNTL_WIND",
    "red"="0:000:TV:CNTL_STEP_DW", and
    "blue"="0:000:TV:CNTL_STEP_UP"
    b.- the above 4 colour keys commands preceded by the "PinP" command "0:000:TV:PICTURE_IN_PICTURE".
    Nothing works Sad
    Question is now:
    Does anyone can change the on screen position of the little PinP window by only using the beo5?
    Thanks.
    Santiago
  • 01-15-2008 8:27 AM In reply to
    Santiago:
    Question is now:
    Thanks.
    Finally I've found a solution by myself Smile and now I can change the on screen position of the little PinP window with the beo5.
    Thanks.
    Santiago
  • 01-15-2008 9:03 AM In reply to
    Are you going to inform everyone of the solution you have found ?
    Regards Keith....
  • 01-16-2008 3:22 AM In reply to
    Of course !
    very easy: I've forget the macros and separate the 2 commands in 2 different buttons, so now I have 5 buttons, not 4... but it works fine.
    Cheers
    Santiago
