frankmj: Which IR-codes do you use? Details please!
/Frank
Details:
I'm trying changing PinP window position on the avant32DVD screen with HDR2 attached.
I've tried those IR codes inside "P in P..." beo5 submenu screen:
a.- only the 4 simple colours keys:
"green"="0:000:TV:CNTL_REWIND",
"yellow"="0:000:TV:CNTL_WIND",
"red"="0:000:TV:CNTL_STEP_DW", and
"blue"="0:000:TV:CNTL_STEP_UP"
b.- the above 4 colour keys commands preceded by the "PinP" command "0:000:TV:PICTURE_IN_PICTURE".
Nothing works
Question is now:
Does anyone can change the on screen position of the little PinP window by only using the beo5?
Thanks.
