Thanks for the answer, but I'm afraid I may have the wrong cords. It appears as if I have two "A" ends, perhaps. By "spliced" I mean, the cords were cut and there's a B&O connecter on one end (both fit into the back of the speaker and have the same type connection, though the shape is different) and the other end is just copper speaker wire.
I'll place a picture here, and maybe that will help. IF, (and I tend to think with my luck that they are), these cords are insufficient, where do I go about getting proper cords to hook these up?
Thanks again.
- Aaron
http://www.flickr.com/photos/22838606@N06/2193718423/
That's a picture of the two (separate) cords I have. Remember: the other end of BOTH cords is just bare copper wire. Any ideas?! :-/
