1st March February 2012
Latest post 03-16-2008 8:16 AM by jk1002. 23 replies.
01-11-2008 12:08 PM
BeoDane
- Joined on 04-16-2007
- Posts 32
Can't connect Beo4 to AppleTV
Hi, My dealer has tried to connect my BV7 Mk3 to my AppleTV, but all in vain. Everything is fine when I operate the AppleTV with the Apple remote, but does not work with the Beo4. In the BV7 Mk3 the "AppleRemote" has been added and flashed to my BV7. IC led connected to the front of my AppleTV - nothing works on the Beo4. Tried the "iPod remote" option and even "iPodDock" option in the stb list of the BV7 but still nothing - no reaction from the Beo4. The AppleTV has now been connected component on picure, audio via a digital/analog converter and that works (doing this connection as I want to use the AppleTV in a link system so HDMI will not work) Has anyone an idea what is wrong here with the Beo4 connection? Very pleased to hear from any out there having done the same. Apparently it is possible but my dealer can't make it work for me BeoDane
Jez
- Joined on 06-13-2007
- Posts 150
Re: Can't connect Beo4 to AppleTV
You need to connect an ir sensor from the i.r socket on the back of BV7 to Apple TV. 1.) There should be 4 i.r sockets on the BV7 (looks like a 3.5 headphone jack). If Apple TV is connected to, e.g) AV4, then use i.r 4, this then runs to the i.r sensor of Apple TV and stuck on the front. In essence the i.r of BV7 then becomes the i.r of Apple T.V. 2.) Go to connections on BV7, Go to AV4 (or what ever AV you have Apple TV connected with) and select socket, then input what ever socket it corresponds to with the socket you have used on the back. I have a MkII, assuming it should be the same.
BeoDane
- Posts 32
Thanks a lot for your reply Jez, but apparently the menu is different in the Bv7 Mk3 I've connected my AppleTV to AV2 under connections - then as PC - selecting the input (HMDI or Component) and that's about all I can chose in that respect. I do (apparently) not have any option to go into a menu and select the socket of the ir. Am I or my dealer doing something wrong here?
meandmyshadow
- Joined on 04-17-2007
- Posts 339
Because you have a MKIII it has the BeoSystem 3 chassis, in which case each AV input has a dedicated IR control socket. Firstly make sure that the correct IR socket is being used and then ensure that it is correctly positioned on your Apple TV, it should just work.
Munin
- Posts 99
Same problem here ... it simply does not work :( /M
Russ
- Joined on 05-07-2007
- Washington, DC USA
- Posts 641
OK BeoDane, 2 things: The AppleTV can be 'paired' to it's remote, rather like a Bluetooth device to a Cell phone. check Apple.com/support to see how to 'unpair' the box from its remote. Then on the first page of the 'Connections' sub-menu for the AV input you will use you need to change the 'Autoselection' to 'yes', but I don't know why.
Russ
We kid because we love.
Bang & Olufsen Tysons Galleria
McLean, VA USA
Russ
- Posts 641
Russ
McLean, VA USA
Munin
- Posts 99
Hi Russ I guess you've got this to work. Could you please list all the settings. Which PUC, PC (or V-MEM) etc ... please give us all the details ... there is something really strange going on here. Also - what is the name of the "controller-file"? iPod Remote or Apple Remote? /M
Russ
- Posts 641
I wasn't directly involved in the installation involving the AppleTV, so I don't know which label/tag was used, nor which AV-input. But the TV was a new BV-7/US, so BeoSystem 3 PUC. The file is labeled 'Apple Remote'. Russ
McLean, VA USA
Munin
- Posts 99
OK ... so lets take up this discussion again. The AppleTV got a gret boost at MacWorld - especially if you live in the states - and I guess that there should be quite a few Beoworlders interesting in controlling it with a B&O remote. For quite some time this has been claimed possible (if you have the Beosystem3 - separate or built into your TV). I got hte Apple Remote software update but it does not work. I'd be very happy if anyone could provide som info on this. Afterall - if beo produces a "STB-controller" named Apple Remote ... they must have tested it at some stage ;-) Please share your knowhow! /M
Russ
- Posts 641
Hi M, please re-read the entire thread. Including my (accidental) double-post.  Russ
McLean, VA USA
Munin
- Posts 99
Well - I have read the entire thread These are my settings: AV5 (and the IR Remote Controll Cable is plugged into the corresponding PUC) Source PC Automatic selection Yes HDMI A And the "Stb controller software" or whatever the name is for it is called "Apple Appleremote" Is there anything else that I should be aware of?
/M
Alex
- New York, NY
- Posts 176
I've had the same problem with an Apple TV for months ... fortunately the customer also purchased a BeoMedia so it wasn't all that important at the time. Now Post-Macworld-Keynote it's certainly an issue that I need to resolve. The weird thing about my installation is that I have a BV7MKIII originally connected to and controlling the Apple TV. That unit was replaced with a BeoSystem 3 and BV4 65" shortly afterwards and thats when the controls in the PUC controller just stopped working! I'm going to do a little bit of experimenting and I'll post my results!
Store Manager
Bang & Olufsen Broadway
927 Broadway
New York, NY 10010
Russ
- Posts 641
Have you made certain to 'unpair' the Apple TV and it's included remote? Russ
McLean, VA USA
BeoDane
- Posts 32
Hi Alex, How is (was) your BV7-40 Mk3 connected to the AppleTV? My dealer and myself are still having problems and it's unsolved. Apparently many users are struggling with this problem, despite the stb list of "Apple Remote", "iPod Dock" and "iPod Remote" in the stb list. Could you please give a detailed list to "Connecting AppleTV to BeoVision 7-40 Mk3 for Dummies" so we can use our Beo4 and Beo5 to control the ATV Input very much appreciated! Thanks in advance Alex BeoDane
beojeff
- Joined on 11-29-2007
- Posts 543
With my Avant and Apple TV, I found that I could not use the "V.Aux" command (if connected to the V.Aux input) on the Beo4 but rather had to use the "TV" button on the Beo4 to toggle to the Apple TV connection. Granted, this is a Beosystem 1 based system rather than a Beosystem 3 based system -- still I thought it might be of some help.
Munin
- Posts 99
I fully agree "Connecting AppleTV to BeoVision 7-40 Mk3 for Dummies" is precisely what I am after right now. After all ... connecting the TV to a Humax HDTV STB was no problem ... but the AppleTV - no way. How hard can it be???
Bastie
- Joined on 12-21-2007
- Posts 17
I have: AV2: VMEM PUC: AV2 STB: Apple Remote HDMI: A Autoselection: YES I unpaired the Remote of the apple tv. Still doesn't work??? What am I doing wrong.... &
Bastie
- Posts 17
I have: AV2: VMEM PUC: AV2 STB: Apple Remote HDMI: A Autoselection: YES I unpaired the Remote of the apple tv. Still doesn't work??? What am I doing wrong.... ps. dreambox 500 no problem... ( i even switched IR cables to check if this one was broke)
Munin
- Posts 99
Beo serviceman was here again - this time also the iPod Remote software was installed, but still it is not possible to control the AppleTV with Beo4. Those of you that succeded must have done something very special. Could there be differences in BV7-40 Mark III in US versus Europe that could explain these problems? /M
Russ
- Posts 641
More food for thought on this topic.... Last night I brought home a new AppleTV and connected it to an Avant/US which has the 4.7 software installed, and the 4.7j CCDB. Attached to the STB input, everything works, everything. I did not have to 'unpair' the remote. I just had to struggle for a few minutes getting the correct resolution output from the AppleTV. If it's this easy on an Avant, there ought to be no problems on BS-3 based systems. Russ
McLean, VA USA
jk1002
- Boston USA
- Posts 1,620
It works on my BV8 including fast scroll and forward/backward. Some of the sources are not linked to an IR control port. I have mine under TV, HDMI Yes, STB Ipod Remote. It worked under DTV as well. I believe it can even work with a paired remote as long as you pair it with the IR plug that is attached to the cable. I think most ATVs ship with an unpaired remote ayway. Cheers JK
Page 1 of 1 (24 items)
