Hi Keith...
1. What Beovision is the STB connected too?
Beovision 3 32
2. Are you sure that the correct STB has been selected from the list in the Beovision STB list ?
The connection is to Pace ntl (as set up by the dealer) the actual model is Pace DI4000T which does not appear on the list (I just tried the other Pace models available but with no luck).
3. Can you confirm that the STB works perfectly with its own remote control ?
Yes (just tested it and the information comes up fine)
4. When
you have selected the STB as the source on the Beo4, if you then press
MENU on the Beo4 do you see a list on the left of the screen something
like the picture in my previous posting ?
Yes, I get the following:
red
blue
yellow
green
1 guide
2 menu
3 interactive
4 internet
5 browse
6 email
7 on demand
8 audio
5. Has this ever worked or is this a new configuration ?
Not as far as I can remember, I just subscribed to movies, so for the first time ever the info button would be useful
I have also just changed the batteires on my BEO4 just in case - but no luck.
Thanks for taking the time reply.
Dan
