1st March February 2012
Latest post 02-25-2008 12:11 PM by jmarcedo. 17 replies.
01-08-2008 7:58 PM
jmarcedo
- Joined on 12-17-2007
- Posts 25
Connect a Beomaster 6500 to non-B&O speakers
Hi everyone! I've made my first B&O purchase on eBay - a Beomaster 6500 and a Beogram CD 6500 - but unfortunely I don't have any B&O speakers... Is there a way to connect a pair of regular (B&W DM 600) speakers to my Beomaster 6500? Thanks in advance, Jorge Marcedo Coimbra - Portugal
Jorge Marcedo
Coimbra | Portugal
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Re: Connect a Beomaster 6500 to non-B&O speakers
jmarcedo: Hi everyone! I've made my first B&O purchase on eBay - a Beomaster 6500 and a Beogram CD 6500 - but unfortunely I don't have any B&O speakers... Is there a way to connect a pair of regular (B&W DM 600) speakers to my Beomaster 6500? Thanks in advance, Jorge Marcedo Coimbra - Portugal
Hi Jorge, Welcome to BeoWorld Beomaster 6500 has sockets for both active and passive speakers, so you can connect regular speakers to the Beomaster 6500. You can hook up 2 pairs of passive speakers. Do you have a remote for the Beomaster 6500 ? For basic control you can use a Beolink 1000, for advanced control you need MCP 6500 or Beolink 5000 or 7000
Ignace
- Moderator - NL
- Posts 2,749
This is an overview of the connections on Beomaster 6500, on the top left are the sockets for 2 pairs of passive speakers
jmarcedo
- Posts 25
Thanks for your quick help, Ignace! It was very helpfull, although I still don't know where to find cables with the apropriate sockets to connect my speakers to the 6500. Additionally, I buy a Beolink 1000 remote control, but I've got to find out how to configurate it to work with my system... Cheers! Jorge Marcedo Coimbra | Portugal
Jorge Marcedo
Coimbra | Portugal
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
The speaker sockets at the rear of the 6500 are standard 2 pin DIN, the plugs (either solder or screw type) can be obtained from any electrical components retailer, when wiring the cables the positive connection is to the small round pole & negative to the flat spade. Alternatively, ready made speaker cables can be found on ebay. The beolink 1000 doesn't need any configuring and will work just fine. You may need to ask again on here when you come to tune in the radio stations as it isn't straight forward for someone who hasn't done this before. Chris.
Ignace
- Moderator - NL
- Posts 2,749
example of how the standard 2-pin DIN plug looks like. The small pin is + , the flat pin is -
jmarcedo
- Posts 25
Thanks again for your fast and complete advise. I already bought the connectors and will try them late at night. I'll give you feedback on this. Concerning the Beolink 1000 matter, I simply tried to command the Beomaster and the Beogram CD with it, but aparently nothing happens. Do I have to do anything, like some kind of reset or something? Cheers, Jorge Marcedo Coimbra | Portugal
Jorge Marcedo
Coimbra | Portugal
Ignace
- Moderator - NL
- Posts 2,749
You could try : SOUND, 1, STORE (whilst Beomaster is in stand by)
Medogsfat
- Posts 4,045
Ignace is correct - this will set your Beomaster to the correct option for a stand alone item : ie not part of a linked B&O system. Are you sure the beolink 1000 is working? You can apparently test if it is giving a signal by looking at it through the camera function on a mobile phone whilst pressing any button - although I haven't tried this myself member Craig says it works and I believe him.
jmarcedo
- Posts 25
Good evening, Just to announce that I finally can hear my system, thanks to your tips. The receiver and the CD player are working, and the Beolink 1000 is finally working too! Two questions remain unanswered to me: 1 - How to configure and save some radio stations? 2 - Can I connect the sound of other sources, such as a non-B&O television, dvd player or a vinyl player? Thanks again for your patience to this "rookie" in the B&O world! Jorge Marcedo Coimbra | Portugal
Jorge Marcedo
Coimbra | Portugal
Ignace
- Moderator - NL
- Posts 2,749
Hi Jorge, I am happy to hear that your system is up and running ! Regarding 1; tuning and saving radio stations : RADIO on Beolink 1000. Press GO TO, press frequency (0-9), or use arrows < / > To store: press STORE, then the number you want to store it to, then STORE again. (i haven't used a Beolink 1000 with Beomaster 6500 for a long time, so i'm not 100% sure this is correct....) Regarding 2; connecting other sources : Yes, you can connect pretty much all sources you want, to the TV/AUX socket for example, you can connect your non-B&O-tv. You would need a DIN-to-RCA connector to be able to connect regular RCA-connectors You only need the line-in (1 white RCA, 1 red RCA) for audio of your tv. Connecting a vinyl player: the Beomaster 6500 doesn't have a built-in RIAA pre-amplifier, i'm sure other members can help you with more information about this. Enjoy your system ! Caution, B&O can become addictive, soon you will be wanting more and more !
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Ignace: Regarding 1; tuning and saving radio stations : RADIO on Beolink 1000. Press GO TO, press frequency (0-9), or use arrows < / > To store: press STORE, then the number you want to store it to, then STORE again. (i haven't used a Beolink 1000 with Beomaster 6500 for a long time, so i'm not 100% sure this is correct....)
It was, works for me at least However, after goto-frequency, you'll have to wait a while before the Beomaster decides that you won't be entering any more digits. Only after that it'll actually tune. I was too fast at first... It also wants the tenths always, i.e. to get 104 MHz you'll need to key 1-0-4-0. Ignace: Yes, you can connect pretty much all sources you want, to the TV/AUX socket for example, you can connect your non-B&O-tv.
But how do you select that particular input? I've tried pretty much every key combination I could think of (V.TAPE, TV, SATELLITE, with and without SHIFT) but the Beomaster just won't react. I have my DVD player in TAPE2 now... I don't know which version my Beolink 1000 is; it's the one with a lot of keys, TURN is there but MENU is not.
-mika
Ignace
- Moderator - NL
- Posts 2,749
-mika
I guess the Beomaster doesn't respond because it "thinks" it is part of a system that has both Audio- and Video- master (interconnected). Option 1 means 'more than 1 infrared eye in the same room'. This means you would have to "tell" the Beomaster to relay the sound from the VIDEO source through the AUDIO master (the Beomaster), -- > to have the sound from your tv, press AV, TV -- > to have the sound from your DVD (is called CDV), press AV, SHIFT, CD (applies to the Beolink 1000 you use, with the TURN button)
Note that the Beomaster will only display "AUX" on its display, should you have Beolab speakers with displays, it would show CDV (for dvd) ---------------------------- If you don't have a Beovision, and don't want to use the AV command to have sound from VIDEO sources, you can set the Beomaster to Option 2 (means 1 infrared eye in same room, all commands relayed through Beomaster), which results in Beomaster responding to audio AND video controls / commands. TV will switch to AUX / TV SHIFT + TV = V.AUX SHIFT + CD = CDV SHIFT + V.TAPE = V.TP2 (applies to the Beolink 1000 you use, with the TURN button)
tournedos
- Finland
- Posts 5,808
You were right, that works. I suppose the guy I bought this set from also had a B&O TV sometime in the past. Thanks a bunch!
Medogsfat
- Posts 4,045
jmarcedo: Two questions remain unanswered to me: 1 - How to configure and save some radio stations? 2 - Can I connect the sound of other sources, such as a non-B&O television, dvd player or a vinyl player?
1. Ignace has answered this but you MUST have an aeriel/antenna attached before you even try or you won't get a signal. 2, As for connecting a vinyl player (turntable to us in the UK) if you let us know exactly the model you wish to attach then a full answer will be given as there are several ways of doing this and the best advice depends on this. The obvious turntable would be either the Beogram 6500 or 7000 as these were designed to match cosmetically & work perfectly by simply plugging directly into the phono input socket. The drawback is that they are quite hard to find and tend to cost quite a lot of money - probably more than the 2 units you already have added together. Chris.
tournedos
- Finland
- Posts 5,808
jmarcedo:
That'll work fine, but you'll still need an external RIAA preamplifier (and an RCA to DIN adapter cable), like the Phono Boxes from the same vendor. Preamps can be had very cheap from half-nameless manufacturers, but I wouldn't spoil a nice setup with a marginal preamp.
(I was told before that you can still get the internal RIAA option board for BM6500 from the dealer, but I've yet to make an inquiry myself. However, you'd still need someone to install it for you, unless you're well into electronics) -mika
jmarcedo
- Posts 25
Now I bought the Beo4 remote. What should I do to configure it with my system? Thanks in advance! Jorge
Jorge Marcedo
Coimbra | Portugal
Page 1 of 1 (18 items)
