1st March February 2012
Latest post 02-11-2008 3:39 AM by kirkster. 36 replies.
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Re: They forced me to swap my BEO 4 cinema for a Beo 5 - Did they trick me?
....mr anders(son):my beo4 cinema in white
Am i the only one here that finds this revolting? Sorry! Thats not photo shop either by the looks of it
kirkster
- Joined on 01-24-2008
- Denmark
- Posts 2
Hi, I would'nt trade the Beo4 Cinema for anything in the world. The Beo4 Cinema was only made in a 500 piece production, to fill the gap until the Beo5 was in production, so this will with no doubt be a collecters item. - K
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
Nice Beo4 Anders! I would have no idea how to take my Beo4 apart though.
Molotow
- Joined on 06-09-2007
- Herning
- Posts 50
Its not that difficult, all you need is a small PH-Scruwdriver and a small wrench. Remove the battericover and the batteries, and just start scruing. I´ve heard that a dealer in Jutland has about 10-15 Beo 4 Cinema left...
GuyHui
- Joined on 03-17-2007
- Posts 1,560
Daniel: GuyHui :
how did you get a white beo4 cinema ?
Photoshop?
OK, Mr Anderson's doing a great job then. I think I may send you a picture of my set up in order to make it all white then  Guy
--= "Everything gets done with Patience" =--
--= "Less is More" - Mies Van der Rohe"
--= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
Stars
- London
- Posts 1,483
Molotow: Its not that difficult, all you need is a small PH-Scruwdriver and a small wrench. Remove the battericover and the batteries, and just start scruing. I´ve heard that a dealer in Jutland has about 10-15 Beo 4 Cinema left...
Oh I didn't realise there were screw underneath the battery cover. Hmm I think a Beo4 will be my next paint job! What kind of paint did you use Anders?
mr_anders_son
- Joined on 03-27-2007
- sweden
- Posts 1,032
Henry: Molotow: Its not that difficult, all you need is a small PH-Scruwdriver and a small wrench. Remove the battericover and the batteries, and just start scruing. I´ve heard that a dealer in Jutland has about 10-15 Beo 4 Cinema left...
carpaint and I spray it about 4 times.
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Henry, the fourth screw is under the sticker. DON'T stick the screwdriver through the sticker, it looks awful! (Like an un-ironed shirt ) If you cut a quarter inch strip off an old credit card, keeping a curvy bit, you can gently tease back the sticker and keep it intact. That way, it will stick back when you have finnished. Andy T.
camshaft
- Joined on 04-16-2007
- Pennsylvania, USA
- Posts 575
Just some advice guys if you're thinking of painting it. Use very very light coats, and just keep applying them. You can always put another coat on, but if you apply too much in one coat you'll see unevenness or even running. Also, you'll probably want to do a very light sanding (maybe 1000 grit sandpaper) before the first coat to help the paint adhere and prevent it from flaking off later on. Austin
-Austin (resident audiophile skeptic)
Stars
- London
- Posts 1,483
Jandyt: Henry, the fourth screw is under the sticker. DON'T stick the screwdriver through the sticker, it looks awful! (Like an un-ironed shirt ) If you cut a quarter inch strip off an old credit card, keeping a curvy bit, you can gently tease back the sticker and keep it intact. That way, it will stick back when you have finnished. Andy T.
Thanks for the tip Andy. I guess you've been undressing your Beo4s quite a bit then.
kirkster
- Denmark
- Posts 2
Be very carefull if you take your Beo4 apart... The EL-backlights are very fragile, especially the one at the display. The printed wires must not be bend more than a couple of times before it might fail... Just a warning guys.. - K
