Latest post 02-11-2008 3:39 AM by kirkster. 36 replies.
Page 2 of 2 (37 items) < Previous 1 2
  • 01-22-2008 10:10 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: They forced me to swap my BEO 4 cinema for a Beo 5 - Did they trick me?
    ....mr anders(son):
    my beo4 cinema in whiteWink
    Am i the only one here that finds this revolting? Sorry! Surprise Thats not photo shop either by the looks of it
  • 01-23-2008 4:11 AM In reply to
  • 01-24-2008 3:18 PM In reply to
    • kirkster
    • Not Ranked
    • Joined on 01-24-2008
    • Denmark
    • Posts 2
    I would'nt trade the Beo4 Cinema for anything in the world. The Beo4 Cinema was only made in a 500 piece production, to fill the gap until the Beo5 was in production, so this will with no doubt be a collecters item.
     - K
  • 01-25-2008 2:37 AM In reply to
    Nice Beo4 Anders! I would have no idea how to take my Beo4 apart though.
  • 01-25-2008 5:00 AM In reply to
    • Molotow
    • Not Ranked
    • Joined on 06-09-2007
    • Herning
    • Posts 50
    Its not that difficult, all you need is a small PH-Scruwdriver and a small wrench. Remove the battericover and the batteries, and just start scruing.
    I´ve heard that a dealer in Jutland has about 10-15 Beo 4 Cinema left...
  • 01-25-2008 5:28 AM In reply to
    Daniel:
    GuyHui :
     how did you get a white beo4 cinema ?
    Photoshop?Whistle
    OK, Mr Anderson's doing a great job then. I think I may send you a picture of
    my set up in order to make it all white thenWink
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 01-25-2008 9:38 AM In reply to
    Molotow:
    Oh I didn't realise there were screw underneath the battery cover. Hmm Hmm I think a Beo4 will be my next paint job! What kind of paint did you use Anders?
  • 01-25-2008 9:49 AM In reply to
    Henry:
    Molotow:
    carpaint and I spray it about 4 times.
  • 01-25-2008 3:08 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Henry, the fourth screw is under the sticker. DON'T stick the screwdriver through the sticker, it looks awful! (Like an un-ironed shirtWink )
    If you cut a quarter inch strip off an old credit card, keeping a curvy bit, you can gently tease back the sticker and keep it intact. That way, it will stick back when you have finnished.
    Andy T.
    Poor me, never win owt!
  • 01-27-2008 5:08 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Just some advice guys if you're thinking of painting it.  Use very very light coats, and just keep applying them.  You can always put another coat on, but if you apply too much in one coat you'll see unevenness or even running.  Also, you'll probably want to do a very light sanding (maybe 1000 grit sandpaper) before the first coat to help the paint adhere and prevent it from flaking off later on.
     Austin
    -Austin (resident audiophile skeptic)
  • 01-28-2008 2:38 AM In reply to
    Jandyt:
    Andy T.
    Thanks for the tip Andy. I guess you've been undressing your Beo4s quite a bit then.
  • 02-11-2008 3:39 AM In reply to
    • kirkster
    • Not Ranked
    • Denmark
    • Posts 2
    Be very carefull if you take your Beo4 apart... The EL-backlights are very fragile, especially the one at the display. The printed wires must not be bend more than a couple of times before it might fail...
     Just a warning guys..
    - K
