Hi all,
I've finally got around to repairing my 1976 Beocord 2200 - type 4601, which I've had since new.
The 2 problems are very specific:
1.
When pressing PLAY >, with no cassette inserted, both the tape cogs rotate as expected.
With a cassette inserted, the forward cog (pull) does not rotate, but the rear cog (push) does - resulting in the tape unravelling inside the drive mechanism.
It's as if there isn't enough torque to pull the tape.
2.
When pressing Fast Rewind <<, nothing moves, and then after a couple of seconds, the AutoStop function kicks in, releasing the Rewind button.
All necessary capacitors and resistors have already been changed, new belts from Dillen, and the magnetic reed switch replaced.
3.
Peter - you said that this is a very tweakable unit - would you care to share your expertise here?
Also, as I see it, it has Ferrite heads, not glass - or am I missing something?
All help will be much appreciated.
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
