Latest post 01-06-2008 10:34 AM by Opman. 1 replies.
Page 1 of 1 (2 items)
  • 01-05-2008 5:04 PM
    • beowhit
    • Not Ranked
    • Joined on 04-17-2007
    • Brompton, Kent
    • Posts 26
    Help - loading music onto Beosound 6
    I'm trying to transfer music onto my newly acquired Beosound 6 and I'm having no luck. I'm using Beoplayer 4.65 and copying the albums from CD to n.music then copying to the playlist for the BS 6 and then....nothing.  The BS6 comes up 'USB connected' so I'm probably missing somthing obvious but it's getting a little frustrating! any help would be appreciated.
    Cheers
    Mark
  • 01-06-2008 10:34 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Help - loading music onto Beosound 6
    Hi Mark
    Your computer should see the BeoSound6 as a Universal Mass Storage (USM) decive and treat it like an external hard drive.
    When you copied the music to your computer did you tick the copy management box?  If you did that would prevent the music being copied to the BeoSound6.
     Hope that helps
    Opman.
