1st March February 2012
Latest post 03-14-2008 2:13 PM by jk1002. 10 replies.
01-05-2008 10:59 AM
woodmanta
- Joined on 12-29-2007
- Posts 50
Hi there, I have been given an Apple Tv as a gift (c/w QED HD Lead!!!!!)..... however< im ever concerned about wireless stream of music & images vs hard wire.... Does anyone have some thoughts on wether or not Apple Tv is any good with Bv7's BTW i obviously have an i-mac 2007 version, so deffo NOT a PC man.... Thanks fellow BnO lovers
Life-is all about CHOICE....
mawheele
- Joined on 12-05-2007
- Posts 82
Hi there, I have a BV7-40 MkIII with Apple TV. I would say Music, Photos are outstanding on the TV. I also have an Airport 802.11N router, and the automated syncing is basically seamless and automatic - although not very quick. The Apple TV will come into its own as the video encoding quality improves. I'm also sure it will get improved software after Jan 15 MacWorld (or they may introduce a next gen version.) Mark.
Goldfrog88
- Joined on 06-07-2007
- Melbourne, Australia
- Posts 83
Hi Woodman, Mark's right, the Apple TV uses the 'b/g' version and not the 'n' version of the wireless standard ... hence it's limited to 54MHz transfer. My Apple TV is hooked into a BS3 (same engine as the BV7 I think) but wired for Internet. It streams fine from an iMac after 20 metres of cable length and passing through two 1GB switchers. The only problem is you have to convert video to MP4 for use on the AppleTV. I use VisualHub and occasionally Elgato Turbo264 software for that. The Elgato Turbo stick is a 'must have' for any MP4 H264 video conversions ... it's better than minute for minute. Cheers!
woodmanta
- Posts 50
Thanks Guys,,, i get Sky HD installed tomor... or so they whould have me belive after totally failing to ( or contact me to tell me) install last week... so hopefully once all in I will begn my chosen path.. I have a wireless router so will go for that opt first.. This forum is the nuts... like having many many fine mates who ONLY wanna talk BnO suff... "we are not alone." :o)
woodmanta
- Posts 50
Hey there Goldfrogg,
having now installed my Sky +HD using my BV7:32 MKIII 'ONLY' HDMI ? DVI port.... How the heck do i install my Apple tv whilt utilising the very delicious QED HDMI lead that i was given too.... ????????????????????????????
I would appreciate urs or anyones thoughts please
Goldfrog88
- Posts 83
Hi Woodman TA, I'm guessing from your shorthand that you only have one HDMI/DVI input on your system? If that's the case, to add an Apple TV and use the HDMI, you'll need an HDMI wireless switching box, say with four inputs and one output. Most are remote capable and some can 'learn' commands using IR. If you have converted DVI to HDMI, you'll likely not have sound in the socket and need to use a separate sound cable. Try to use the optical output on the Apple TV---you may need a Toslink to SPDIF converter---as some of the latest HD movie rentals on iTunes can output Dolby 5.1 only through the Apple TV's HDMI output. How do you get movie rentals in the UK? Got a friend in the US? ... ? For TripEnglish, shame about the war ... bought your PS3 yet?
BeoNut1
- Joined on 08-19-2007
- Mobile, AL (USA)
- Posts 226
Goldfrog, I thought the Apple TV was 802.11n? Mark
Mark D
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
yes it is but many still have old equipment that can only do G.
jk1002
- Boston USA
- Posts 1,620
Streaming is not a problem if you do not have a N network. The apple tv will just run under G mode which is a bit slower. I use g, the initial sync was very painfull but now day to day its just a few minutes. JK
Page 1 of 1 (11 items)
