Latest post 01-03-2008 11:06 AM by nobby. 9 replies.
Page 1 of 1 (10 items)
  • 01-02-2008 11:51 AM
    set-top box controller for MX 4000/4002
    Hello,
    Anybody knows if set-top box controllers can be fitted into MX 4000/4002 tvs ?
    Seasons greetings and a happy new year.
  • 01-02-2008 12:30 PM In reply to
    Re: set-top box controller for MX 4000/4002
    Hi!
    Yes you can add one to later models but the problem is that B&O no longer manufacture them
    regards
  • 01-02-2008 12:53 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    There is a STB controller for MX-Beovisions and AV 9000. Works also in old 2-way-Beovisions.
    I think, type nr. is 4030 (?).
    Stefan
  • 01-02-2008 4:34 PM In reply to
    Should be available - I got mine last year.
  • 01-03-2008 12:59 AM In reply to
    Hi!
    I asked B&O three months ago. No longer avaliable
    Let me know if you find any. I need one
    regards
  • 01-03-2008 5:58 AM In reply to
    hagan:
    Hi!
    regards
    I have one in my MX 4000 but it will not work. I heard that it was big problem with this one.
    Mine was bought new and have to change sw in MX 4000 but still doesent work.
    You can buy mine if you want
  • 01-03-2008 8:44 AM In reply to
    What does not work on it?  Have you checked to see if there is output from the IR blaster?  Or is it just the codes that are wrong?
    Neil
  • 01-03-2008 9:17 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    ....mr anders(son):
    hagan:
    Hi!
    regards
    Interested if it ever worked. I had a STB installed in my Beovision3 & the software upgraded to control a Sky Digibox but it wouldn't work. The 'engineer' eventually shrugged his shoulders and said he could do nothing more as the STB controller was OK and the software was now correct. He then left.
    Not to be beaten I moved the stick-on 'eye to a different place on the front of the box and guess what? Worked perfectly!
    I'm not saying that's your problem, but as a warning to others, B&O or not, don't believe all you are told.
  • 01-03-2008 9:24 AM In reply to
    nobby:
    Neil
    The ir codes. I installed it myself, so maybe that why!!!??
  • 01-03-2008 11:06 AM In reply to
    Are you sure its set for the type of box you have?  As the codes are different (but I am sure you know this).
    Neil
