....mr anders(son): hagan: Hi!
I asked B&O three months ago. No longer avaliable
Let me know if you find any. I need one
regards
I have one in my MX 4000 but it will not work. I heard that it was big problem with this one.
Mine was bought new and have to change sw in MX 4000 but still doesent work.
You can buy mine if you want
Interested if it ever worked. I had a STB installed in my Beovision3 & the software upgraded to control a Sky Digibox but it wouldn't work. The 'engineer' eventually shrugged his shoulders and said he could do nothing more as the STB controller was OK and the software was now correct. He then left.
Not to be beaten I moved the stick-on 'eye to a different place on the front of the box and guess what? Worked perfectly!
I'm not saying that's your problem, but as a warning to others, B&O or not, don't believe all you are told.
