Quality Dream Audio have  just started making replacment glass panels for all of the beocenter range even the beogram cd 's and beocord tape decks.
they look good and have a great  black finish with all of the buttons working !
supplided with double sided tape ready to just stick on your clip (with instructions)
the only down side is that there are no markings on the panels and no lights shine through.
not the biggest problem in the world as most people use the remotes.
they do make your equipment look and work as it should though.
the prices are a LOT better than B&O used to be.
they make them to order so you will need to contact them through there web site.
http://quality-dream-audio.co.uk/contactus.aspx
keep your loved B&O going !
