Hi together,
some time ago I already asked for help on the problem with my LC2 (see LC2...). However things have changed slightly since that. Let me describe the whole story:
1. From one day to the other it happened that my LC2 is no longer reacting (almost) and the IR sensitivity of my Ouverture has become poor.
2. To be more precise: The LC2 is no longer reacting when it´s dark in the room, i.e. in general it´s not possible to turn on the light. However it is reacting better the brighter the ambient light is. Manual control by touching the eye is working normally.
3. When taken to another room the LC2 is reacting "almost" normal (however not 100% perfectly when it´s absolutely dark).
4. To operate the Ouverture I have to point the IR control directly to the system (the poor behaviour known by any non-B&O stuff...). This was not necessary before that day.
5. I inspected both of my two remote controls (type Beolink 1000), checked the batteries - no problems found.
6. My MX5500 TV is reacting normally, i.e. I can point to the opposite wall and the TV is reacting normally.
7. My Beolink Passive equipped with an IR eye is reacting normally too!
8. There is no Plasma TV in my flat!!!
Conclusion
It appears to me as if there is any interference with an electrical noise (spread through the mains?) that makes the systems behave as described. Anybody ever heard of this? Any solution?
