Hi guys I wonder if anyone can help me with the problem. The Cd tray on my Beogram Cd player is either moving very slowly or not opening at all. I sustected the drive belt, but I have dismantled the unit and repaced this and its still the same. I now suspect that the voltage feeding the tray motor is to low, I have measured it to be 4volts, the problem is that I dont have a circuit so I dont know what the correct voltage should be? I have tried driving the motor from a 6volt battery and it works fine like this. I there anyone out there who has had the same problem and knows the answer or anyone who could send me a circuit showing the drive motor circuit and voltage, that would be great.Thanks Joe
My name is Joe and my email address is joeliff@hotmail.co.uk
