Hi there,
I'm afraid this is really a low level question, but I did not find an answer for it in this forum-section. I want to place TV channel logos on my Beo5 so that I can select them by pressing the corresponding logo. Do I have to add them under TV-Channels? And which IR-command do I have to add to each logo - the program number under which the channel is "saved" in the BV? Thanks for all answers - Alex.
Alex,
You will add them under channels and you will use the program number it is saved in your Beovision.
If you are in the UK I have some templates I have produced which will be on-line soon which include all the possible Logos
Regards Keith....
