Latest post 12-17-2007 6:12 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 12-17-2007 5:03 AM
    Logos for TV-Channels
    Hi there,
    I'm afraid this is really a low level question, but I did not find an answer for it in this forum-section. I want to place TV channel logos  on my Beo5 so that I can select them by pressing the corresponding logo. Do I have to add them under TV-Channels? And which IR-command do I have to add to each logo - the program number under which the channel is "saved" in the BV? Thanks for all answers - Alex.
  • 12-17-2007 6:12 AM In reply to
    Re: Logos for TV-Channels
    Alex,
    You will add them under channels and you will use the program number it is saved in your Beovision.
    If you are in the UK I have some templates I have produced which will be on-line soon which include all the possible Logos
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
