Keith;
Right. I think the CD cover art is loading in via Media Centre.
Regarding other choices for Album Art:
My routine is to download MP3, or rip a CD onto the PC, and do the following:
1. Check that it is recognized by Media Player ( Library - > Add to Library.
2. I then check and see if the CD album art loaded or not. If it did, and I like it, I leave it.
3. If not, or if I want to use another choice, I use a selection from My Pictures, or download off the internet and store the selection in My Pictures to use.
4. I right click on photo I selected and chose Copy.
5. I then open the Media Player to the new album, and right click over the blank cd cover space. This then brings up choices, including Paste Album Art, and left click it. The photo then copies onto the Album.
6. Closing Media Player, I click into Media Centre, and My Music. The album and the cover should be loaded as in Media Player.
7. Finally Beoport and Beoplayer. N.MUSIC, - > config, - > and scan. It opens as it did in Media Centre, with the selected album art.
8. There is another further step in burning a CD from the download, which can be used in the vehicle or recorded onto the BS 3200. For those also using Beomedia, remember that the unit is also storing all photos it finds on it's Beomedia Hard Drive. This can start adding up, so I periodically move or remove a lot of photos, videos, and other art to storage on a DVD.
Having gone through a HD crash, and later a system reinstall, all music, video, photos, are stored on an external hard drive 500 G LaCie Porsche Design, which compliments the overall B&O design in the Living Room.
I hope this is helpful.
