I have problems changing sources. My setup is a BV6 (with DVB-T & front speakers) masterlinked to a BS9000. On the Beo4 I can watch DTV, and then press CD (TV turns off and CD kicks in), and visa-versa. But on the Beo5 I want the following:
Zone 1 - BS9000 - CD1
- CD2
- CD3
- CD4
- CD5
- CD6
- Radio (Analogue). In this submenu I have Radio1, Radio2, etc, etc
BV6 - (sub menu containing all the DTV channels)
DAB - (sub menu conating all the DAB stations)
From off I can press BS9000 (CD starts OK, press CD 2 (for example) and clamp moves and CD plays). Now press 'Radio-Analogue' then (for example) BBC Radio 3 (from within the BS9000 menu) and the CD moves to no.3 (it hasn't selected Radio it has only seen the no. 3 button). This is quite simple to correct - I need to add a 'radio' button to all my radio stations?
Now if I press BV6 (CD shuts off and DTV comes on). All OK. Now Press DAB and DAB kicks in. All OK. Now if I want to go back to TV I press BV6 (or any of my channel logos) and it wants to change the DAB radio station as per my channel number, it doesn't shut down DAB and start DTV mode. If I press BS9000 it works OK and the DAB shuts down and the BS9000 starts, the Radio-Analogue aslo works from here.
Having typed this out this is starting to make sense (I think). God, this is a knightmare.
Ian
