The Beosound 5 encore comes standard with a pin code. The dealer you bought it from must supply you one. Then you can replace the factory code woth your own code. It's a theft protection pin code.
if you not bought it by a Bang & Olufsen dealer i assume you will have a problem. so i hope you bought it by a Bang & Olufsen dealer and he forgot to give you the pin code.
