Well, it is like this... I have a Beocenter 9000 with a pair of generation 1 Pentas. Currently the cd player is busted, or more like the plastic part that holds the cd down is gone. So I'm using a generic cd changer through the aux port. The real problem is that sound only comes out of one speaker. I checked the speakers and the wires, and they are fine. It just so happens that which ever speaker is plugged into the Speaker 1 left port, is the speaker that doesn't work properly. The display on both speakers always works correctly though. I found out that a little bit of sound will come out of the left speaker if it's turned nearly all the way up.
Any thoughts?? I would really love to get sound out of both speakers! Thanks.
