Dear all,
Thanks for a lot of help so far. However, I do have a small problem with my Beogram 4000 lifting the arm a little early on some 7" singles, not playing all of the music. On other 12" albums, it sometimes does not lift the arm when the album is finished. I tried adjusting one of the contact springs ("A" in the service manual), resulting in 7" records being played all the way and the arm lifting, but then it wouldn't lift on 12" albums. Argh! Do you have any advice?
