Lifestyle:
You provide a nice, minimalist, well-organized photo concept.
There are sample illustrations in the BV-10 operation manual, available to Beoworld Gold members. However, without more specifics, a few questions arise:
1. What is your actual wall construction ?
2. Distance between speakers and BV-10 ? Same with the subwoofer ?
3. Distance to mains/electrical supply ?
4. Distance to additional B&O or other stereo system, cable, SAT TV, or HTPC components ? Are you also planning to M-L link the system into other rooms ?
If helpful, I ran a horizontal conduit under the BV-10 to the BL 4000 active speakers we use. This is silicone conduit which facilitates easy cable pulling and no snags. Our location is masonry, not easy but at least to code.
