jldmelb:
With digital television looming, and the switching off of the analogue system, I would still like to be able to use my MX4000 with my BEO4 remote ONLY...
Does anyone know if a Set Top Box controller can be fitted to an MX4000??? I'd like to avoid having to use one of those horrible plasticky remotes!
The Beo MX STB controler is for the whole MX TV family incl. AV9000. Also works in earlier 2 way models (!) - Beo says it doesn`t work, but it does.
I have one fitted in my old MX4000 and one in my AV9000, both 2 way ans can be controled via BL5000/7000. Unfortunately the controler is not produced anymore, so you have to find a used one.
Second option would be a Lintronic box. www.lintronic.dk Your stb can be controled via the -238 box using the MX IR eye and a special SCART cable. Works from linkrooms too.
Third option is a special SCART cable that includes the IR converter made by oneremote. www.oneremote.dk. They also modify stbs for Beo4/5 use.
Fourth option is Ulf. Ulf also modifies third party devices for Beo4/5 use. www.ulf-kiener.de I have a sat box and a DVD player modified by Ulf. Works great.
Hope this helps
Stefan
