Latest post 07-15-2010 6:22 AM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 07-14-2010 11:20 PM
    Question re MX4000
    With digital television looming, and the switching off of the analogue system, I would still like to be able to use my MX4000 with my BEO4 remote ONLY...
    Does anyone know if a Set Top Box controller can be fitted to an MX4000??? I'd like to avoid having to use one of those horrible plasticky remotes!
    My B&O: 2009 Catalogue and Pricelist
  • 07-15-2010 1:58 AM In reply to
    Re: Question re MX4000
    As long as it is not a very early one (pre Beo4 model) the answer is yes. However finding a STB-C will be tricky as B&O no longer supply this model.
  • 07-15-2010 2:51 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Peter :
    If it is a DVB-T/S SetTopBox you want to use - there is an other possibility.
    A DVB-T/S receiver with build in code converter - connected to AV1 or AV2 (beeing configured e.g.
    as "V.Tape/V.Aux/DVD/...") using a SCART-Cable.
    I'm using such a solution on a LX5000/BeoLink1000 - works perfectly
    My old TV "believes" to control a B&O-VCR and the receiver is also placed out of sight
    http://www.iq-tec.at/home.html  (Site unfortunately only in German language)
    Beeing B&O dealers for many years they know exactly the needs - they are using "Technisat/Orbitech"
    products (made in Germany) as a platform and are implementing the code-converter into the STB.
  • 07-15-2010 6:22 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    jldmelb:
    The Beo MX STB controler is for the whole MX TV family incl. AV9000. Also works in earlier 2 way models (!) - Beo says it doesn`t work, but it does.
    I have one fitted in my old MX4000 and one in my AV9000, both 2 way ans can be controled via BL5000/7000. Unfortunately the controler is not produced anymore, so you have to find a used one.
    Second option would be a Lintronic box. www.lintronic.dk Your stb can be controled via the -238 box using the MX IR eye and a special SCART cable. Works from linkrooms too.
    Third option is a special SCART cable that includes the IR converter made by oneremote. www.oneremote.dk. They also modify stbs for Beo4/5 use.
    Fourth option is Ulf. Ulf also modifies third party devices for Beo4/5 use. www.ulf-kiener.de I have a sat box and a DVD player modified by Ulf. Works great.
    Hope this helps
    Stefan
