Hi, the green led on your BeoSound says it has a timer stored in it, is your BeoSound linked to a video master (BeoVision)?
Besides, can you use the manual keyboard on the BeoSound but not your Beo4? In that case, it means your system is set to option 0 (no remote control), you need to set it back to audio option 1 or 2 to be able to use the Beo4 again.
Which speakers are connected to the BeoSound?
Reunion Island is greeting you!
