Latest post 01-16-2010 3:10 PM by Mark. 2 replies.
Page 1 of 1 (3 items)
  • 01-16-2010 2:25 PM
    • Mark
    • Not Ranked
    • Joined on 01-16-2010
    • Suffolk, England
    • Posts 6
    beosound 3200
    Hi, I confess that I just joined as a bronze member as I have problem with my beosound 3200. I cannot switch it on (tried everything).  BUT I can play a CD through it using my beolab 3500 which is linked! There is a red & a green light on but no life otherwise.  Resolution tips gratefully received. Thanks, Mark.
  • 01-16-2010 3:04 PM In reply to
    Re: beosound 3200
    Hi, the green led on your BeoSound says it has a timer stored in it, is your BeoSound linked to a video master (BeoVision)?
    Besides, can you use the manual keyboard on the BeoSound but not your Beo4? In that case, it means your system is set to option 0 (no remote control), you need to set it back to audio option 1 or 2 to be able to use the Beo4 again.
    Which speakers are connected to the BeoSound?
    Reunion Island is greeting you!
  • 01-16-2010 3:10 PM In reply to
    • Mark
    • Not Ranked
    • Suffolk, England
    • Posts 6
    Re: beosound 3200
    Hi & thanks for replying. OK, The Beosound is not linked to a vidoe master, only the beolab. I cannot use anything on the beosound keyboard or the beo4 on the beosound but the beo4 will operate the beolab.  I have a pair of 6000 speakers.
