Hello all,
I’m new here and this is my first post. I
share with you some kind of fascination for B&O products and philosophy
although i do not always adhere to B&O ultra elitist strategy. Nor do i
support the B&O’s inertia and isolation in a rapidly changing digital
world. Like some of you, i have hoped and waited for years that B&O and
Apple conclude some kind of strategic alliance, which seem so evident from a
customer’s perspective. This is the reason why i now have a bunch of questions
about Mac/B&O integration, for those of you who would be patient enough to
advise.
Currently i live with a family and a
BS9000+BL8000 at one end of my living room. Plus a PowerMac at the opposite end
… And two BL 3500 in other rooms, linked via ML. The PoweMac is linked to others in the house via ethernet, and wired to the
BS-9000 Aux entry. So, I can play my iTunes music (but AAC or MP3, alas) on my
BL-8000.
Now comes the big upgrade : i was lucky
enough to buy a pair of BL-5 at a fair price on eBay, and will also add a new
BV 8-40 to the picture (and sell my B-8000), moving from a pure audio system to
a A/V system.
What i would like to understand is how to
integrate the whole Mac+B&O stuff to be able to :
1- Capture max audio benefits from the BL-5
potential (connecting BS-9000 through pure digital output seems to be highly
recommended)
2- Play my iTunes music on the BL-5, assuming
i will be able to re-code part of it into Apple Lossless format from the
originals. And also be able to play from time to time some AAC music from some
passing by guest iPod …
3- Interconnect BL-5 and BV 8-40 to be able to
make it a 3.1 A/V system (i do not have nor appreciate rear speakers for
« special » 5.1 display). The BV 8-40 will be fed by a Satellite,
ADSL input, DVD  or blu-ray in the
future.
4- Display picture shows or personal videos
stored somewhere on the ethernet network on the BV 8-40 / BL-5 system. I have
lots of digital photos (>20000, managed with iView Media Pro) on my hard
drives and create (shoot+edit) videos on a separate, dedicated work station.
Would like to kind of use the living room to display the result of (and
justify !) what I’m doing all day long in my dark cabinet …
So the questions that are obsessing me are
like :
- What’s the best set up to aim for ?
- Should i connect BS-9000 directly to BL-5 (digital) or connect
     BS-9000 to BV 8-40 and BV 8-40 to BL-5 (but then : is it a digital
     input , to keep the digital/analog convesion within the
     BL-5 ?) ?
- More generally, is it possible to have ALL sound inputs flow into
     the BL-5 as digital signal, not as powerlink analog signal ? If yes,
     how to switch form one input to the other ? Or, should i necessarily
     connect everything to the BS 9000 first, and then have BS-9000 linked to
     BL-5 as digital input ?
- What is the best set up to store and display on BV 8-40 my photos
     and videos ? A physical wire between my PowerMac and the BV
     8-40 ? Or add an Apple TV module to the BV 8-40 that wireless
     connects to the PowerMac. I know this works well with iTunes music, but
     what about iView Media Pro (not iPhoto) ? And HDV videos ?
I have the feeling
this becomes really tricky, but as many of you i dream of a full Mac / B&O
integration … Could you help me think this out ?
Thank you !
