I used the computer to burn a CD to play on the BC2500 but it won't [purchased CDs work fine]. The CD does work fine on the Beosound 1. Is there a problem with the CD player on the BC2500 or simply something to do with the way the CD is burned?
Thanks in advance for your help.
Is it a CD-RW? A lot of players have issues with CD-RWs, such as my CD7000. If not, try burning it at a lower speed, or try a different brand of CD-R.
Weekly top artists:
Regards Graham
My old Beocenter 9000, would not play CD-RW Discs. It would play 90% of CD-R's without any problems.
Craig
Sorry, double post.
Durban South Africa
Check iTunes is definitely burning an audio CD, and not an MP3 CD or Data CD.
I even cannot read some purchased cd on my BC2300, such as Massive Attack Collected..., which is perfectly admitted on my BC2 and Beocenter AV5....
Laurent.
Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
Well then i think your laser is weak,and need to be replaced. Is it a BC2300 with the radial swingarm laser or the vertical unit?
