Latest post 05-07-2009 10:59 AM by kronzilla. 10 replies.
Page 1 of 1 (11 items)
  • 08-26-2007 9:31 AM
    • Wings
    • Top 200 Contributor
    • Joined on 04-17-2007
    • Hong Kong
    • Posts 341
    Burned CD not playing on Beocentre 2300
    I used the computer to burn a CD to play on the BC2500 but it won't [purchased CDs work fine].  The CD does work fine on the Beosound 1.  Is there a problem with the CD player on the BC2500 or simply something to do with the way the CD is burned?
    Thanks in advance for your help.
  • 08-26-2007 10:43 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Burned CD not playing on Beocentre 2300
    Is it a CD-RW? A lot of players have issues with CD-RWs, such as my CD7000. If not, try burning it at a lower speed, or try a different brand of CD-R.
     Weekly top artists:
  • 08-26-2007 12:02 PM In reply to
    I'm not surprised. Many CD players of this vintage have problems with burnt CD's. It's something to do with reflectivity. As Alex suggests, try another brand and definitely burn at the slowest rate.
    Regards Graham
  • 08-26-2007 12:18 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    My old Beocenter 9000, would not play CD-RW Discs. It would play 90% of CD-R's without any problems.
    CraigSmile
    • Craig
    • Posts 4,855
    Sorry, double post.Smile
    CraigSmile
  • 08-26-2007 3:52 PM In reply to
    And use 700MB not 800MB Smile
  • 08-26-2007 4:12 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Durban, South Africa
    • Posts 808
    • Gold Member
    As i;ve posted before, my CD3500 plays CD-R. CD-RW. and copy write protected. Doesn't like itune burnt cd's for some reason. I don't use Itunes so its ok
    Durban South Africa
  • 08-26-2007 6:30 PM In reply to
    • Alex
    • Posts 2,990
    Check iTunes is definitely burning an audio CD, and not an MP3 CD or Data CD.
     Weekly top artists:
  • 08-27-2007 9:28 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Thank you all for your advice.  I will give your suggestions a try.
  • 08-27-2007 11:35 AM In reply to
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    I even cannot read some purchased cd on my BC2300, such as Massive Attack Collected..., which is perfectly admitted on my BC2 and Beocenter AV5....
    Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
  • 05-07-2009 10:59 AM In reply to
    Well then i think your laser is weak,and need to be replaced. Is it a BC2300 with the radial swingarm laser or the vertical unit?
