maybe a stupid question but did you measure the Ohms of the coil?
There's a copper wire from the terminals to the actual coil on the conus that is flexible. I had a driver where that wire was broken and resoldering (carefully, not to make it solid with all the solder-tin) helped.
HTH,
Gunther
