Hi Jason,
what I SHOULD have in the menu, according to the manual I have, is the AV option, which I can change for whatever device I connect to it, and also a decoder option for the 3rd scart socket - it is this option which doesn't appear so this socket is unusable at present.
Thanks for your help with the manual Jason
Chris.
