        1st March February 2012
	    Latest post 06-09-2007 4:30 AM by Beo . 13 replies.
									                 Keith Saunders
 Joined on 04-16-2007Technical Advisor, Little Ann, Hampshire, UKPosts 3,810 |
										    Re: is it a problem for beocom 4?
										    How old is your Beocom 4 ? Have you always had this problem or has it just occurred ? |  |
									                 Craig
 Joined on 03-29-2007Costa Del St Evenage Posts 4,855 |
										    No problem like that on my Beocom 4.   Craig  For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen.. |  |
									                 Christian
 Joined on 04-16-2007Copenhagen, DenmarkPosts 626 |
										    Maybe the ecco is generated in the reciever's phones. You can check this by having the guy you speak with muting the microphone. If this helps then you don't have a problem, if not you could have a faulty phone.Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century. Addicted? Oh no.... ;) |  |
									                 BeoJoined on 04-17-2007Posts 108 |
										    well, it is not echo, echo comes a little bit later than my voice. But for this case, when i speak, it seems that I can hear my voice louder when the phone is stick to my ear.  It seems that the sound does not come from the speaker. |  |
									                 Keith Saunders
										    Beo, I understand the symptom you have described, but the reason I asked the two questions before is that there was a software change that effected sound reproduction, so How old is your Beocom 4 ? Have you always had this problem or has it just occurred ? |  |
										    I appreciate your help, thank you very much. well, it is a very new one, just a month old only. This happens since the first day I use it till now. |  |
									                 StarsJoined on 04-24-2007LondonPosts 1,483 |
										     Beo: I appreciate your help, thank you very much. well, it is a very new one, just a month old only. This happens since the first day I use it till now.
 That certainly isn't right then. I only got a new BeoCom 4 recently and the sound reproduction has been excellent and with no such problem. Contact your dealer. |  |
									                 meandmyshadowJoined on 04-17-2007Posts 339 |
 As Henry said it is not right, return it to your dealer and ask for a replacement. |  |
										    well, thank you all of you.
 I have contacted B&O repair service technician, his reply is that it is normal to listen our own voice from the speaker area. They even use this to judge if the phone is okay or not.
 I discover that the problem only happens if I speak loudly (compartively), since today when I speak gentlely, it is perfectly okay. But if I speak loudly, I can hear my voice, and sometimes a little bit "cracking" like noise sound.
 So what do you think?
 Also, please help me to do an experiment. Connect the line without pressing number, I guess you should hear a long "Do..." sound, then try to speak a little bit louder at this time, I can hear my voice loudest in this situation from the speaker. |  |
										     Beo:well, thank you all of you.
 Ask him to bring you another BeoCom4 and test it, if it is the same then fine, if not demand a replacement. |  |
									                 RyanJoined on 04-16-2007TorontoPosts 29 |
										    Mine has an echo as well when I turn up the volume beyond 60%. But I guess I shouldn't expect much for only nine times the price of a normal cordless phone. |  |
										    i always keep it in the 3 loudest volume level. Will this affect much? |  |
						     Page 1 of 1 (14 items)  |
