1st March February 2012
Latest post 06-02-2007 9:13 PM by Jandyt. 8 replies.
06-01-2007 4:58 PM
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
We have Beoport in our den connected by Masterlink to an Avant and Beosound 3000 in one room and link speakers in another room. Today I noticed on Beoport the sources TV and CD have disappeared. I went to the sources menu to add them back in but they are nowhere to be found. How do I get those two sources back? Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Razlaw
- Illinois
- Posts 1,770
Thanks for the suggestions. I went to check the option and for some reason it appears I now have Beoplayer instead of Beoport installed? When I I open the Guide it gives me the Beoport instructions but when I go to the settings menu it is for Beoplayer, there is no ability to get into the Advanced settings where the options are. Appears I may need to reinstall Beoport.
Razlaw
- Illinois
- Posts 1,770
I clicked on the Beoport Icon on the desktop and reinstalled the software and all works fine now. Thanks for all of the input.
Page 1 of 1 (9 items)
