Latest post 06-02-2007 9:13 PM by Jandyt. 8 replies.
Page 1 of 1 (9 items)
  • 06-01-2007 4:58 PM
    Beoport Question
    We have Beoport in our den connected by Masterlink to an Avant and Beosound 3000 in one room and link speakers in another room. Today I noticed on  Beoport the sources TV and CD have disappeared. I went to the sources menu to add them back in but they are nowhere to be found. How do I get those two sources back?  Thanks!
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 06-01-2007 5:33 PM In reply to
    Re: Beoport Question
    It sounds as if your Masterlink cable has become disconnected from your Beoport, or at least that was the case when your PC was booted.
    I suggest you check the cable and if OK reboot your PC and check again.
    Regards Keith....
  • 06-01-2007 6:35 PM In reply to
    Vhat is the Option number of you beoport?
  • 06-02-2007 3:11 AM In reply to
    For most situations the option would be set to "6"
    Regards Keith....
  • 06-02-2007 10:32 AM In reply to
    Thanks for the suggestions.  I went to check the option and for some reason it appears I now have Beoplayer instead of Beoport installed? When I I open the Guide it gives me the Beoport instructions but when I go to the settings menu it is for Beoplayer, there is no ability to get into the Advanced settings where the options are. Appears I may need to reinstall Beoport.
  • 06-02-2007 12:09 PM In reply to
    Interesting, not sure how that could have happened without user intervention
    Regards Keith....
  • 06-02-2007 8:47 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Razlaw.
    Beoport is a tangible object (Blackbox) whereas Beoplayer is a computer program.
    If you click on Beoplayer icon, I think there is the option to "repair".
    Andy T.
    Poor me, never win owt!
  • 06-02-2007 9:08 PM In reply to
    I clicked on the Beoport Icon on the desktop and reinstalled the software and all works fine now. Thanks for all of the input.
  • 06-02-2007 9:13 PM In reply to
    • Jandyt
    • Posts 13,004
    Nice one!!!
    Very warm glow, I can still help someone even when I can hardly string a sentence together!!!
    Going to bed now.
    See you all tomoprrowSleep
    Andy T.
