Hi Jeff,
Again I am in Washington, DC. If you can help locate a MCL 2A relay box I would be grateful.
Two questions though:
1) Since connecting a pair of BeoLab 6000 via PowerLink to the BeoMaster 6500 PowerLink outputs defeats the Speaker 1 outputs for central room speakers, can I use a Y PowerLink connector to connect on one side the BeoLab 6000 pair and on the other side a MCL 2P amplifier to which I connect a set of passive speakers? I suppose the PowerLink outputs would be able to handle the load.
2) Can I connect a second pair of passive speakers to a MCL 2A, or would that blow up the unit? I am trying to circumvent the one MCL 2A I am lacking.
Thanks for your advice.
David
