Morning all, can you advise on the below?
We have beo-link in the house and in the office there is a beoport box with and infra red eye attached to it and beolab 4000 speakers. There is also a PC (XP) and a Mac.
I am trying to move from the pc to mac and have come accross some issues
Current setup
PC with Beoplayer linked to beoprt via usb, this works fine and if the PC is on the IR with beo4 remote also functions normally and N music/Radio is available in other rooms in the house.
What I want to do is move over to the Mac as the source of N Music/N Radio and use the beo4 remote to switch to normal radio, cd, turntable etc in the office.
Mac setup (pc unconnected and off)
latest Itunes (as of Feb 01/08), BM-Link 1.5, Beoport firmware 1.31 linked via usb.
With this set up the Mac is happy as the source of N music and N radio and in the other rooms I can switch between sources with the beo4 remote such as cd radio and N Music with no problems.
The problems are in the office, I have control over the N Music/Radio with the beo4 remote but if I try to switch to another source such as cd or radio nothing happens.
Has any one else got a similar setup or encountered similar issues?
I am happy to supply more detail if you think it will help
Thanks for reading
Richard
