I am looking into buying a BeoLab 3500 for the kitchen, but there is one part of the functionality that I can't find documented anywhere: does it work independently with respect to the main speakers?
What happens to the main speakers when I'm in the kitchen and, say, start a CD remotely via the BL 3500? Will the main speakers sound as well? (I know the volumes can be controlled independently, but that's not the question.)
The same question apply in reverse: when the CD (or TV or whatever) is turned on in the main room, will the BL 3500 be turned on in the kitchen as well?
Finally there is the question of separation and overlap for the remote control (Beolink 1000). The kitchen and the main room are adjacent with a wall and a door between them. Could it be problematic to have a zone where both the BL3500 and the main unit pick up the signals from the remote control?
Sigmund
