Hi, does anybody know how to program a "SHIFT-GREEN" IR code?
I understand GREEN == CNTL_REWIND == SHIFT REWIND, but there is no dedicated "CNTL" command available in the config tool. So how can I achieve "SHIFT-SHIFT-REWIND"?
I need it for my STB (this example is PiP), attached to a TV set to "cursor mode" (=new Beo4).
In config tool I can select "cursor mode" for the STB device (products tab), but in EDIT tab it's translated as "PLAY-GREEN" (the syntax for the "old" Beo4) nevertheless. To my understanding the "cursor mode" in products tab just control the behavior of the cursor of the Beo5.
Any idea?
