Latest post 12-07-2011 9:06 AM by kurfuer. 2 replies.
Page 1 of 1 (3 items)
  • 12-07-2011 5:57 AM
    • kurfuer
    • Not Ranked
    • Joined on 04-22-2007
    • Dresden
    • Posts 35
    SHIFT-GREEN for Beo5
    Hi, does anybody know how to program a "SHIFT-GREEN" IR code?
    I understand GREEN == CNTL_REWIND == SHIFT REWIND, but there is no dedicated "CNTL" command available in the config tool. So how can I achieve "SHIFT-SHIFT-REWIND"?
    I need it for my STB (this example is PiP), attached to a TV set to "cursor mode" (=new Beo4).
    In config tool I can select "cursor mode" for the STB device (products tab), but in EDIT tab it's translated as "PLAY-GREEN" (the syntax for the "old" Beo4) nevertheless. To my understanding the "cursor mode" in products tab just control the behavior of the cursor of the Beo5.
    Any idea?
    Filed under:
  • 12-07-2011 8:27 AM In reply to
    • hfat
    • Top 500 Contributor
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Re: SHIFT-GREEN for Beo5
    I would code as:
    0:00:TV:SHIFT
    0:00:TV:CNTL_REWIND
    hfat
  • 12-07-2011 9:06 AM In reply to
    • kurfuer
    • Not Ranked
    • Dresden
    • Posts 35
    cool, it works Big Smile - Thank you!
    I was not aware, that it is possible to insert free codes, instead I was just searching in the provided codes - thanks a lot for giving this hint.
    regards, Dirk
