Fellows,
I have the BM5 and the BS5. these devices are connected with the 9 mter cords. Who has experience with this?
Is this tested by B&O??
official BM5-BS5 cables installed. All works fine
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
how long are the cables??
@Carolpa: how long are your cables between bm en bs???
Zwaan: @Carolpa: how long are your cables between bm en bs???
9m
I currently have 4.5 m but I would like to exchange for a. 15m.Does anyone have experience with cable 15 m?
see internet for max on USB, it is limited! and 15m is beyond the limit
you hace to use a usb-cat5/6-usb solution
I think mine are the 9 meter ones.
Carolpa,
Hoe weet je dat het officiele kabels zijn?? De dealer zegt ook tegen mij dat het originele kabels zijn. Maar ik is op mijn usb-kabel kijk dan staat er gewoon CHINGLUNG (chinees merk). Wil jij kijken wat er bij jou op je usb kabels staat??
alvast bedankt
for what I could see, I didn't find any names or codes. The USB cable is build of two parts of 4.5m. One male-male and one female-male cable
(helaas geen namen of codes. kabel bestaat uit twee delen)
