Latest post 12-06-2011 1:31 PM by Carolpa. 10 replies.
Page 1 of 1 (11 items)
  • 12-05-2011 12:59 PM
    Distance between BM5 and BS5
    Fellows,
    I have the BM5 and the BS5. these devices are connected with the 9 mter cords. Who has experience with this?
    Is this tested by B&O??
  • 12-05-2011 1:05 PM In reply to
    Re: Distance between BM5 and BS5
    official BM5-BS5 cables installed. All works fine
  • 12-05-2011 1:21 PM In reply to
    I have no problems, other than I very much wish a one meter or even shorter cable were available.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-05-2011 1:33 PM In reply to
    how long are the cables??
  • 12-05-2011 1:35 PM In reply to
    @Carolpa:  how long are your cables between bm en bs???
  • 12-05-2011 1:42 PM In reply to
    Zwaan:
    9m
  • 12-05-2011 3:27 PM In reply to
    I currently have 4.5 m but I would like to exchange for a. 15m.
    Does anyone have experience with cable 15 m?
  • 12-05-2011 3:36 PM In reply to
    see internet for max on USB, it is limited! and 15m is beyond the limit
    you hace to use a usb-cat5/6-usb solution
  • 12-05-2011 5:15 PM In reply to
    I think mine are the 9 meter ones.
  • 12-06-2011 9:40 AM In reply to
    Carolpa,
    Hoe weet je dat het officiele kabels zijn?? De dealer zegt ook tegen mij dat het originele kabels zijn. Maar ik is op mijn usb-kabel kijk dan staat er gewoon CHINGLUNG (chinees merk). Wil jij kijken wat er bij jou op je usb kabels staat??
    alvast bedankt
  • 12-06-2011 1:31 PM In reply to
    for what I could see, I didn't find any names or codes. The USB cable is build of two parts of 4.5m. One male-male and one female-male cable
    (helaas geen namen of codes. kabel bestaat uit twee delen)
