1st March February 2012
Latest post 05-31-2011 4:50 PM by kallasr. 4 replies.
05-31-2011 11:43 AM
ajames
- Joined on 05-04-2007
- Posts 275
Av2 Expander Part number 8089111
Just seen one of these on e-bay and I'm wondering if it would work with an RF Avant VCR. The manual seems to point to it being for MX Tv's but then a previous version of this expander worked with Avants as well by setting the AV Socket to Video Tape 2
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
ajames
- Posts 275
Re: Av2 Expander Part number 8089111
Thanks blackrix - saved me an expensive mistake probably - there is no expander in the menu so will leave will alone.
Thanks again, always good to have this forum to refer too if in doubt
Guy1680
- Joined on 08-18-2007
- Viborg, Denmark
- Posts 104
I think it may be useful and work with the Avant. From the manual for my Beovision 3:
AV 2 Expander
The optional AV 2 Expander accessory is a SCART expander for connection of non-Bang & Olufsen equipment, such as decoders, game consoles, and cameras to the DECODER socket on your television. Use a 21-pin cable to connect one plug to the socket marked TV on the Expander box, and connect the other plug to the socket marked DECODER on the television. Remote control operation of equipment connected via the AV 2 Expander is not possible.
I have an AV2 expander but have not tried it with my TV. Sadly I don't have time to try it before that auction ends!
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Just buy it, test it, tell us, if it does not work, sell it for 1 Euro less...
-> worth a try - I would say! <-
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Page 1 of 1 (5 items)
