I also got a beocenter9000 and a
remote1000 with the package---the displays do work using that but as I want them for fronts in my HT/Stereo guess I will
live without the displays.
Question
The beocenter9000 cassette tape door won't open is there a manual override to
get it open???
The CD load door works fine and also the
amp is fine as it plays CDs flawlessly.
Tape door isn't a big issue unless easy fix
as I don't need it to play tapes anyway.
I'm still stoked my trade was
Beresford 7520DAC in return I got
BeoLab Penta Mrk1's
BeoCenter9000
BeoRemote1000
After hearing the Penta's I would make this
deal all day long----they are just gorgeous
no dings and one little pull in the grill cover
you can't find unless you know where it is.
My first experience with B&O and I guess
I'm on my way to being converted.
Lefty11
